- May 17, 2015
- 165
G'day
Posted up a while ago in the general section but Im getting closer to collecting all the bits and pieces and have some questions before I go to mauch further. A bit of background.
I have a large universal mill, want to build a Z axis head that I can use manually or in NC mode, not at full cnc needs yet.
I have a 5HP vector duty motor and a 10HP control techniques drive that has option to fit with a 1.5axis motion control for the spindle, the motor is 230V 3phase and the drive is 400V which is my power supply, I have done the research on this and have done a similar conversion on my lathe so am fairly confident with this part.
Not sure what is the best way to attack the servo drive set up? I have picked up control techniques servo drive and an AC servo motor rated to 3000rpm and 7.7Nm coupled to a 7:1 precision gearbox. Its all brand new, cables and all. But is it too big?
The next part of the equation is the spindle head, I need to buy a BT40 head off a VMC and machine a carriage to hold it, belt driven off the motor, I have questions on the drive ratio needed there.
Now I don't know if I should solid mount the motor and drive a ball spline shaft to the belt pulley to allow z axis movement of the spindle head only or build a carriage with large hiwin linear rails to carry the whole lot like on a cnc VMC?
How do I size the the ball screws? I am goind to use this as a powered z axis feed for general machining but I would also like the option of using it in semi manual mode to use similar to a drill press (on steroids)
Is this possible?
Cheers Str8.
Is this possible?
Cheers Str8.
