Build Stock Around Part Machine From Solid and Pattern Your CAM
BladesIIB
https://www.youtube.com/c/BladesIIB
H-M Platinum Supporter
Sep 1, 2020
554
How to put your stock on a Pallet and ensure you have the correct offsets when using a single point of origin. To do this you need to create stock around your design and then machine from a solid instead of machine from a relative size box like in a vise. Took me a little bit to figure this out. Initially, I was just using a joint to connect my part right to the pallet, but then the offset was not correct and not aligned to my single point of origin.
