- Apr 22, 2016
- 988
I'm looking for experienced info on silver soldering of band saw blades. I've watched videos and made a jig and scarf soldered with the flux and solder I had on hand. They came out straight and ran good in the saw but don't last long before the joint comes apart. What I'd like to know from those of you that do this is:
1. type brand and source for solder (% silver, I assume hard 75%)
2. same for flux
3. heat source you use (I have a standard propane bottle torch and a small butane torch)
4. any other special techniques
Thanks for your time to answer these queries.
Aaron
2. same for flux
Aaron
