- Feb 2, 2016
- 55
I picked up a Brown & Sharpe Tool Makers Universal Vise recently. I want to disassemble it to clean it up. I am stuck and could use some guidance. Here is the Vise.
I removed the swivel Base and bracing levers.
That leaves the Vise connected to the angle base.
I would like to remove the vise from the angle base, but I'm not sure how. Below is a picture of the Vise upside down with the angle base open. In addition to the swivel base, the vise also swivels on the angle base. I removed the locking bolt and I stuck a screw driver in the slit to spread the hole on the angle base thinking that I could pull the vise out. Spreading the slot allows the vise to lift about .030", but that's it. I'm not sure why. Next I tried to loosen the three slotted cap screws on the round pivet block that protrudes through the angle base and seem to connect it to the vise, but they do not budge. I assume they are standard right hand threads. I don't want to break anything.
Any ideas?
Thanks,
Greg
Any ideas?
Thanks,
Greg
