I have acquired a combo horz / vert milling machine (Armor 5H). Horizontal spindle is #9. I purchased an B&S arbor for gang milling used, it has a tang. It will not seat all the way in, it hits a hard stop, metal to metal. I have other threaded arbors that fit properly. Whats up? I have read this taper is capable of holding, although the copy of the book by Cincinnati milling states they stop making ganged arbors with a tang. I will need to make a draw bar, its on my list to restore this mill. I CAN see all the through the spindle hole, it is not blocked. Any info on what to avoid in getting tooling for this spindle would be helpful.
I will have other questions as I work on this mill. Thanks for any help and applicable information.
