Broken compound retainer
jwmay
H-M Supporter - Gold Member
Ok fellas...what would you do about this? I found this after I’d bought the lathe, but only recently have come to a point where I can no longer set the compound for threading. There’s no more iron to tighten the compound to.
Seems like my best option is foregoing the repair entirely, and bolt a big chunk of iron where it used to be.
I would call the manufacturer and email those pics as well perhaps they can help you out
A hundred dollars ain’t bad!
Well now for the confession. The damage when first discovered, wasn’t nearly so extensive. I was still brand new to machining. The first time I changed the angle of the compound, one t bolt felt mushy. It wouldn’t get tight. Upon inspection, I discovered the t bolt was stripped, and bent, the nut had pulled threads, and the cross slide had a big chip out of it. I didn’t have a clue what to do about it. I made a crappy t bolt, that kinda worked for awhile. Then I found a t bolt that was for attaching railings to SKF conveyor...I installed it on the lathe, and I believe over the next months, chipped out all the rest you see there. That t bolt had very little surface area for bearing. So, this...or most of it, is my fault I believe.
Today I made a replacement t bolt, a little heftier than the original. I can tighten the compound slide correctly for now. Only time will tell if this will last. But I might buy a spare cross slide just to have it. I thought it had to be expertly fit up. Meaning I don’t think I’m capable, of it requires any scraping, or precision. If I can just slap it on there, and everything would be fine, there’s my Christmas I guess!
Thanks all!
Its the ways in the saddle that are important. As long as the cross slide has the right angles for the dovetail, and are parallel (counting the gib, if a tapered gib), the rest is not critical.
