Hi all, thanks for the ad to the forum.
I recently acquired an old Atlas 6" lathe, model 10100. It looked like it was in fairly good shape from initial inspection, and it has the cast iron head stock and legs. Apparently the old gentleman that I got it from was the original owner, but it seems that he was not an honest fellow! After I got it home I decide it would be a good idea to clean and lube everything. So I started with the top slide. As I was sliding it off the casting fell apart in my hands! It had been glued back together and excess glue cleaned up so it looked fine. With the tool post attached it actually seemed to work fine when I tested it at the previous owners house. If I had actually taken the time and chucked a piece of metal, and taken a cut, it probably would have been pretty apparent that something was wrong. But I did not so here we are.
Is there any way to fix this, welding, brazing or am I just wasting my time thinking about that?
Thanks for any advice on this.
Regards, Nick.
Regards, Nick.
