Hi
I have a 1991 Bridgeport with a 48" table and a Bridgeport power feed. I was recently milling down a large aluminum plate which required moving the table in X very close to the stops. Now the table has become extremely stiff and I can barely move it in X, even near the centre of the table where it always moved easily. I have to use two hands to turn the crank and power feed really struggles to move the table. I have checked the bearings by the handles at each end and they are good. I loosened the gib screw two turns and tapped on other end and the gib moved so it is not seized. The table did not get easier to move when the gib was loose. Is it possible for something in the Bridgeport power feed to be binding, even when it is not engaged? Or has anyone ever heard of the brass feed screw nut becoming seized? Usually they wear and become sloppy rather than stiff. Before this happened, there was quite a lot of backlash in the screw (over .100). Wondering if anyone has ever seen this before or might have some ideas where to start? I don't really want to pull the table off if that is not the problem.
Dave
Dave
