Bridgeport romi Headstock alignment
sasanifab
Oct 3, 2020
80
This is a ezpath 2… For the life of me I cant find the 4th bolt that holds the headstock on. Has anyone here ever worked on these machines ? I have loosened two on the left and one on the right. I cant find anything
The BP Romi is a Nardini. Mine has the same type of adjsuters. There are two bolts holding the gear box to the bed below the spindle face and two more on the backside in the drive belt cabinet. There should be a second adjuster like you pictured on the back side as well.
So on my lathe there is a small panel underneath the chuck where the adjusters are . I managed to remove the two bolts where the drive belt is and the one to the right of the chuck, the nut or bolt closet to me i cant find
I might have had to pull the gap to get to the cover on the inboard side of the head. Have you found a Romi manual?
I have all the manuals…. Doesnt say ****. Its just mentions 4 shims … No mention of bolt locations…
