- Dec 23, 2022
- 10
Hello! I've been a reader of Hobby Machinist for a long time but this is my first post so I'll try to keep it from getting too long!
The backstory is: I recently bought a very used 1959 Bridgeport mill. To get it running quickly I purchased an cheap VFD, which I wired up and it seemed to work fine (although I never ran it for more than a few minutes). After reading many posts about how the cheap import VFDs weren't safe and lacking complete confidence in my electrical skills I chose to buy a new static phase converter from a US company. At first it didn't work properly so the company sent another capacitor to wire in parallel. This seemed to work but after running the mill for about 5 minutes it began billowing white smoke (hopefully not too toxic since it filled by garage).
So I have two questions: What was the cause of this and what is the best route for getting the mill working?
My thoughts on the cause are that it's an old motor (pancake style) and most likely has lots of wear/friction combined with running on two phases which caused the motor to overheat (insulation breakdown was the smoke?) I plan to test continuity between the three phases and ground to see if there are any shorts now.
Assuming there are no shorts to ground, I could: Try to switch back to the VFD and see if the issue was the motor running on two phases. Or, try to find a larger three phase motor to turn my static phase converter into a rotary.
If there are shorts would it be better to send the motor to a local shop to rewind it? (But then I'm back to the same question as above, just with a newer motor.)
Or buy a new 1 phase motor from H&W, looks like it would be about $1000 but it sounds like turn key solution.
The mill ways are very worn looking and it has quite a bit of backlash in the lead screws so I don't know if its worth putting too much money into. This is also 100% used for learning/hobby and doesn't make any money.
Thoughts? Thanks for any input to help me decide a path forward!
