“16 ounces of: Mobile Velocite #10 spindle lubricant. This will be used in the spindle quill bearings on the 2J and 2J2 mills.
16 ounces of: Mobil DTE Heavy/Medium (ISO 68), which will be used to lubricate the spindle downfeed, drawbar spines, pulley cam, and spindle bearings (on the J and M head).
16 ounces of: Mobil Vactra #2 Way Oil, which will be used to lubricate the sliding Way surfaces of the mill, (The X, Y, and Z ways, and axis screws.
A tube of Lubriplate B105 grease (1 3/4 OZ) for the bull gear shift mechanism. This should get about a half a teaspoon squirt of grease every six months. I would guess this tube should last 2 or 3 years. The “B” in the B105 is Lubriplate’s designation for the formulation for the Bridgeport. The story (as told by Lubriplate), is that Bridgeport printed Lubriplate 107 on the lubrication plate on the side of the machines, and decided to let the mistake go. If you call Lubriplate looking for 107, this is what they will recommend. I’ve gotten this story from two different souces in the business, and thats good enough for me.”
