Hi I have a round ram Bridgeport that I picked up a few months ago. The mill did not have a head, and I was able to get a J- head and mount it. It’s far from perfect, but it works for this back woods machinist.
The machine is in my shop, which has a good roof, but certainly not climate controlled. So, when we get sticky or drippy weather, unfortunately, my machines are sometimes prone to condensation. Well, the last couple of weeks, I haven’t been able to use the mill, and keep ahead of the moisture. I usually try to keep after it with Kel protective oil spray, but a bit of surface rust came in in spots. Not really a problem that a wire brush and a little scotch bright won’t take care of.
The big problem turns out to be the knee elevating gears and handle. When I went to Jack up the knee, it was really hard to move so hard, in fact I ended up snapping off the handle, and when I used the splined end with a pipe wrench to try and get the knee up, I started to skip teeth with the bevel gears on the elevation screw.
Obviously, something has bound up and will need to be taken down and freed up, just wondering if anyone else has ever had to deal with this situation, and could give some wisdom.
