- Jul 20, 2014
- 1,386
I recently worked with a shops J head BP mill, older, maybe circa 1970's.
I had trouble with milling and hole accuracy. I know something is bad with
the spindle. Just sensing that it is not running true or to spec, TIR.
I did not check with DTI but just looking at surface finish and hole quality I could
tell something is amiss.
Has anyone here ever rebuilt their BP spindle or had it done?
I've read lots of threads on the web about this problem and You Tube has a few
videos showing the process.
Can this job be done on site with all the parts and what else could be replaced while
the head is apart? Is there a one stop shop that sells all BP parts? Is the BP manual
on rebuilding any good? Thanks
