- Jul 20, 2014
- 1,386
I'm thinking of changing the collet alignment screw on the BP at work after my new R8 collet started binding. (old collets do not bind?)
The job looks pretty straight forward, but I have a question. Do you have to knock the spindle down and out a bit to access the small screws?
And will this action change the pre load on the bearings? I've never changed this alignment screw or have even removed the spindle nose, which may also
need a face pin spanner. Or can I access the screws w/o knocking the spindle down (with a dead blow of course).?
