Hey guys,
I've got a Bridgeport J-Head, serial #J262246 that's making a good bit of noise up in the step pulley housing area. I've removed the step pulley housing, as well as the spindle and this is what I've found.
1) The splined gear hub is quite worn, both on the internal splines for the spindle, as well as on the external 'cog' splines that engage into the spindle pulley hub above it.
View media item 95706
2) It also appears that the spindle splines are quite worn as well
View media item 95705
I'm including a video of the machine making the noise while in back gear.
Let me know what you guys think.
1) Is thing worth rebuilding
2) Get a replacement J-head from eBay
3) Buy an Accu head from eBay
Would anyone happen to have used parts? Or possibly a good working J-Head that you'd like to sell.
1) HQT1160 Splined Gear Hub
2) HQT1414 R8 Spindle Only
Thanks in advance
Paul
Thanks in advance
Paul
