I have a Bridgeport Series 1 CNC mill that is missing the top parts in the head, roughly from the cast iron up. The parts needed include:
1. The bottom half aluminum casting
2. The vari pulley mechanism
3. The bearings
4. The shafts, pins, nuts and bolts, etc.
5. The upper aluminum casting
6. The motor
What is have in place is the low speed shaft and the 'splined' main drive shaft. The high low shift lever is in place and moves the main drive shaft.
Thank you,
Dan
3. The bearings
6. The motor
Thank you,
Dan
