I've been silver soldering blades for a while with good success. Somewhere someone mentioned they should be annealed after soldering so I tried it, might be the particular solder Im using but every blade I did would break at the joint. Quit annealing and the blades quit breaking. Hum. I've had this roll of silver solder a long time, can't remember the melting point, maybe I'm getting too close to the melting point at the annealing temp?
Greg
