- Aug 29, 2019
- 999
Yep spent a couple of hours getting the cone gears off the cone gear shaft . They must all be removed from right to left to get to the farthest one on the left which is the one that drives the cone shaft. I ordered an 18 tooth gear about 3 weeks ago to replace what I thought was the last one on the left (the drive gear) Bozo likes to speed read assy drawings and the 18 tooth gear is really a 16 tooth gear and it is part of the cone shaft (not removable) . This is the gear that was the damaged one so I do not need the 18 tooth gear. So I've spent the rest of the afternoon doing the shop research to determine what gear cutter to use to re-cut the teeth on the shaft.
So here is the deal. The O/D of the gear is 1.110 inches. the number of teeth is 16. so not knowing what the DP is I did the math. I came up with a DP 16 14.5 pressure angle and cutter #2 from the 16 D/P set. Somebody want to check my math before I invite Bozo back over.
#Note to self: Stop trying to speed read.
