Boyar shultz 612 grinder oiler issues
BCwoods
Aug 19, 2021
35
This is one is the oilers that lubricats the way side. It's blocked good. Iv tried soaking it, noodling it with a wire, and tried to blow air through it but nothing. It almost looks like I could press it the center but would probably destroy it.. any ideas?20220817_211456.jpgIMG_20220817_204445.jpg
Small drill bits, or welding torch tip cleaners.
There is much more to that Bijur meter than meets the eye.
It is not cleanable by any means.
Replace any that do not flow oil.
There are numbers on the side as well as an arrow.
The wrong meter will not work with your system or installation backwards will not flow oil.
These units contain a filter ( prone to clogging) a check valve and a restriction.
I've had some luck clearing oil metering valves from a Bridgeport by boiling them in water and Dawn dish detergent. I let them soak in the boiling water for ~1/2 hour and sometimes you get lucky and they break free. If not, replace.
Ted
Oops..that is a BiJur. I wish you had showed a side view. Most think they are plugged but it is a jet that only releases oil under pressure. Depending on machine, yours is about 20 psi. BiJur was bought by Delimon or something like that. I buy my replacement metering units from LubeUsa.com in South Carolina. Devco comes up under searches. They mark them up 50%.
Here is a picture from the Bijur Delimon catalog
