- Jul 6, 2022
- 513
I may be buying a new milling machine and I’m considering making the stand myself, as the stands that come with these machines are pretty bad.
The mill is 320kg (roughly 700lbs) and I want to make the stand essentially a cube.
What wall thickness and dimensions would be best for that weight and application?
Also, I remember seeing that adding same to the inside of the box section would help add weight and dampen vibrations. Is this worth it?
Thanks in advance.
Thanks in advance.
