I bought an atlas 10d over a week ago in good condition with all the change gears. First thing is the grease is leaking out of the countershaft when running, so im assuming the felt is worn out. Another one is i am missing the washer that goes behind the screw gear(part 9-114) and cannot find one, any leads where i could find one or atleast the thickness of the washer so i could make one... And last question is regarding the change gears, i need to cut an 8tpi thread eventually and knowing what gears to use is no big deal. my question is for some gear changes do you need to loosen the bolt in the banjo so it can move up or down and give you room to mount the 96t gear with the 32 on the screw for 8tpi? Thanks
