- Jul 4, 2014
- 156
Guys,
I am trying to bore a 1.5 inch deep hole in 6061 aluminum of 1 inch OD using my 9x19 Grizzly G4000 lathe. Hole has to be quite precise to 0.708 inch (18 mm) diameter to mate a shaft. I am using 1/2 inch shank carbide tip boring bars I bought from Little Machine Shop. Lathe runs at 1000 RPM setting. The piece is held in my 6" 4 jaw chuck and 1000 rpm is the highest speed I am willing to run it. next speed setting available is 2000 rpm and I am too scared to try it.
I wasted three aluminum pieces till now. Each I got very poor finish. I have made sure that every thing - all gibs, tools and everything is tight. No play of any kind. The boring bar is quite thick and should not flex (I hope). I take very tiny cuts, never more than 0.002 inch at a time. I use plenty of WD40. The finish I get is terrible, almost like a sand paper to touch. The boring bar was never used before this and therefore new as shipped by LMS. It is set at precise axis height.
Where am I going wrong? What will get me better or smooth finish?
Thank you
Prasad
Eastern PA
Thank you
Prasad
Eastern PA
