Evening Guys-
Making my first real attempt at boring something other than aluminum and am running into issues. Hoping someone here with a lot more knowledge than I can tell me where I am going wrong.
I am working with stainless round stock. Diameter of 1” and 6” in length that is running true in the 4-jaw with +/- .002 TIR. I have a 3/8” boring bar with carbide insert installed in the QCTP and hanging out just a hair over 3”, which when I rotate the stainless should allow me to bore the entire length. I drilled out the stock with a 1/2” drill bit and am now attempting to bore it the remainder with a plan of leaving a wall thickness of .01”.
So here is the problem… God awful chatter and a terrible finish. I have tried adjusting the speeds and feeds. Double checked that my tool is on center. Reduced the tool hangout down to 1”. Tried running dry as well as the other extreme end with way too much oil. Swapped the insert for a fresh one. No matter what I try I get a terrible squeal, chatter, and the finish is not even close to usable.
Would appreciate any advice you guys have to offer.
Thanks!
Thanks!
