- Jun 12, 2018
- 724
I have a few questions about boring heads for mills.
I have a Precision Matthews PM-25MV mill and I was wondering what type of boring head to get? Is there a specific one I should get for my mill or anything with an R8 shank will do?
I'm countersinking block of steel for an allen shoulder bolt. The diameter I need to drill is something like 13.13mm
I don't want to keep buying odd sized drill bits, so I'm thinking of getting a boring head so I can just adjust for the size hole I need by the thousandths.
I used a 1/2" drill bit to drill the hold and I need to make it slightly bigger. Will a boring head do the job?
Does the boring head also cut the bottom of the work piece all the way to the center or does it just cut the side of the hole?
