I need to purchase a boring head for a new project. Having never used one, I have a few questions:
1. When the description says it is a 2" or 3" boring head, does that refer to the maximum diameter that can be bored or is it that diameter plus 2 times the offset .
2. I cannot image how to use the horizontal bore rod hole found in some boring heads except as some type of fly cutter. What use is the horizontal bore rod hole?
3. Is it better to get a boring head that accepts 1/2" or 3/4" boring bars or a boring head that has an adapter to permit the use of both diameters?
4. Are boring heads typically run at the same rpms as a similar diameter fly cutter?
5. Would the maximum diameter of the boring head be be restricted the same as the mill's specification for the maximum size face cutter? Example: my G0704 manual suggest a maximum face cutter of 2 1/2 inches.
6. I reserve this space because I know I forgot something.
Thanks
Thanks
