Boring Head- Minimum ID
rwm
Robert
H-M Lifetime Diamond Member
Mar 25, 2013
5,180
I have a Criterion boring head DBL 202 with a Mesa insert holder. This exact setup:
Mesa claims the minimum ID for this is .925 using a CCMT 32.51 insert.
The problem is when I uses this for holes less than 1.5" I am dragging the heel of the insert. I believe these inserts have a 7 deg relief? This can be figured out trigonometrically for someone smarter than me. Is Mesa incorrect or am I doing something wrong? Have you seen this issue? Could I get an insert with greater relief?
I assume the tooling has a flat that prevents it from rotating in the boring head?
Otherwise, I'd just clock around a degree or so to gain a bit more relief.
It has a flat. Also that would make it into a negative rake cutter.
Maybe give Mesa a call?
I did. They said 0.925.
Could be that their .925 info is not accurate.
Have you tried moving the tool into the center location?
Here is the question diagrammatically:
Assuming a 7 deg relief angle, what is the minimum radius of a circle before the heel contacts the work?
There is a SIN, COS, TAN in there somewhere!
Edit: SIN 7 x .1563 tells you that the heel is recessed by 0.019
