- Jul 14, 2024
- 1
I have an old craftsman floor model drill press that I've been modifying lately. It's pretty much your basic drill-to-mill conversion story. I'm not looking to plunge cut steel or anything. Just light stuff. Light passes.
As many of you know, the taper can't handle much in the way of side loads. It will disconnect and drop. So I'm trying to add a drawbar through the spindle where it would thread into the top of the shafts tang. I'm thinking a threaded rod (#8-32) will do just fine. But... I have to bore a hole for it first.
I just have no real way to drill this hole and stay centered all the way through the spindles 15" shaft. The obvious answer is to use a machine lathe. I mean really, if I find a wood lathe that has a through-hole spindle, then I could probably use it. The steel seems relatively soft enough.
I have zero lathes available to me.
I guess I'm just looking to pick y'all's brains. Any ideas? Is this a bad idea?
