I need to bore a 1 27/64" diameter hole, 7/8" deep in a 1" thick piece of mild steel. I will then thread it 1.5-12tpi with a tap. I am guessing that I should bore to depth with an end mill. What do I need to use after that to bring it to finished diameter and keep the bottom flat?
Does anyone have a suggestion as to how I keep such a large bottoming tap perpendicular to the work?
I'm working with a HF radial R8 mill.no rotary table.
Thanks
Thanks
