Bore bar Setup
frankly2
H-M Platinum Supporter
Mar 27, 2017
213
Made this tray out of Masonite to hold all the tooling for my boring bars and bushings. it's nice to have all the tools in one place and ready for setup. need to make some more bushings for the 1/4" bar. All three bars are carbide with indexable inserts. I like to keep things organized, seems to shorten set-up time.
Very nice! It looks like it could be hung on the wall like a painting. I wish I was as organized...:rolleyes:
Nice and neat!
I wanted to suggest to you that you consider not piling your inserts together like that. The edges can chip if they bang against each other; I learned this from experience.
Nice and neat!
I’m very careful not to shake or bang things around. Have a special place for the set so it’s easy access and safe.
Okay, just wanted to be sure you were aware.
Thanks for the reminder. I did do another small task today in the same light. A collet and accessory holder for my 9in SB, pics here. I really enjoy playing with my toys !
Nice and neat! I am needing to do some similar organizing of my smaller items and such. How did you construct your trays, glued only?
Using Masonite material, glue with Elmers Wood Glue and reinforcing corners with small round dowels glued into inside corners. I had some long stem cotton swabs that were a gift from a hospital warehouseman, which I cut to use as dowels in all the inside corners and glued them in. All the Masonite I machined with my 8520 mill so the butt fit was precise and accurate, which made the gluing hold best. I know that’s a little overkill but I know the trays will last a long time. Anyway it’s fun and eye pleasing to make, not to say time consuming ! ! Wife thinks I’m a nut case ! Maybe others do also ! The collet holder was put together with epoxy, but I did not reinforce the corners. I gets no abuse so it’s holding up just fine.
My shop certainly is not as clean and organized as I want, but it’s functional and I take care of my tooling, can’t afford not to ! Too expensive to waste !
