Black and Decker #60 Drill Press
Awround
Jan 21, 2021
48
I have restored an old Black and Decker #60 Drill Press for a friend. The drill press was purchased by her Grandfather in the early 1950's.
As delivered:
All the parts were derusted using electrolytic rust removal and then the castings were cleaned, primed and painted.
And the finished project:
Cheers,
Adrian
That turned out excellent :encourage:
Now to find the uninsulated B&D drill to match it; I damn near got electrocuted by one of them back in the 1950s.
Like this one on Ebay? :)
No, the one that I had was a 1/4" size. Those were the days before U ground plugs, there was just a pigtail wire sticking out the side of the plug to connect to what?
I remember that, this one has it too. I wonder if this is the type that's supposed to go with this press?
My dad a similar B&D press and the matching 1/4” drill which this battery version is a copy of. Dad gave it away after 50 plus years of use.
Pierre
It looks like it would accomodate a large varieties of drills of different sizes.
A bit more digging in my friend's basement and we came up with the matching drill. It is a 5/8" Black and Decker 576 Heavy Duty.
I stripped it down to inspect and clean. 70 year's worth of assorted dirt/crap inside the motor housing (brought in by the cooling fan).
They made things well back then. The reduction gear box is all running in roller and ball bearings. Not a plain bushing in sight!
The reversing switch is a large collar on the back of the drill that rotates between three detents (fwd, off, rev). After a good cleaning everything went back together and it runs beautifully. Now to find it a new home.
Cheers,
Adrian
