Hi I did search this forum and no one has admitted here of doing this so I'm asking for help I have Top Tech BF46 Mill and thinking of converting it to CNC -very green on the topic my understanding is that lead screws need to be change? so there is a hardware portion fro the machine then hardware to connect to PC the place I bought the mill has a hardware set not sure how good that is? Isee they use belts
https://www.machinetoolswarehouse.com/xcart/catalog/BF30-BF46-CNC-Retrofit-Kit-p-16333.html
would direct mounting kit be better? anyway can I convert to CNC but still use the hand wheels when I choose to for manual work?
What about motors and control boards? I read somwhere that steeper motors are less acuurate due to "step movement"? any thoughts on that
I see many different opinions on the software -which one is the simplest to use or easiest to learn
Thank You for all the help in advance
Paul.W
Paul.W
