If you're talking about checking a vee way, the simplest is taking a small vee block, setting it on top of the vee, upside down. Either mike the thickness from the top of the vee block to the underside of the bed way, or measure the height from the top of the vee block to a flat spot on top of the bed. This will give you a fairly accurate measurement within a couple of thousands. It will at least tell you that your bed is worn in a given area, if you're lucky, no wear at all.
Now if you are wanting to make a "scraping iron" as I call them to scrape a vee to, I would suggest to talk to Richard about doing this. My preference is to get the bed re-machined and work from this.
Ken
