- Nov 23, 2020
- 820
Hi all,
I am in process of making a belt grinder (Vendelay) and am working on the main part. Hot rolled steel 500mm x 160mm or about 20" x 6.4"
I have used carbide face mills to get it nearly to final thickness, but I want to get a more consistent surface finish. Let me to fly cutter, but nothing off the shelf is big enough to get a 160mm wide pass. Thoughts on best way to get a better surface finish? I want to cold blue the part, so trying to get it looking as good as I can.
Thanks for any suggestions. I own a 1340 lathe and an 833 mill, so I can make something if needed.
