- Jan 21, 2015
- 67
I've tried several methods to cut a circle from a sheet, all are unsatisfying. What do the pros do?
I've tried a jeweler's saw, but my 1/8" stock is way too thick for that. You should have 3 teeth in the thickness of the stock, but my coarsest sawblade puts about 12 teeth in 1/8". The sawing is thus very, very slow. After cutting 15 degrees around the circle, I calculated that a full cut would take over 2 hours. And the circle would still need finishing afterward.
I have tried milling 3 shallow blind recesses on the back of a square piece so as to accomodate the 3 jaws of my chuck. Then I mount the piece on the lathe, spin it up and cut with a simple RH cutter. For 3mm thick stock, this does not work well. With my tiny lathe (a Sherline 3"), it took most of an hour to cut a 2" circle from 1/8" thick aluminum. The tool must cut on only one side (or it stalls), so a long series of widening cuts had to be made.
I tried the same trick to mount the piece (on a chuck) on a rotary table on the mill. I can bring the mill up to the edge, then turn the entire piece. Again, 1/8" thick is too much metal to turn through. If I take 0.07mm per pass (this is what my machine seems to like), then 3.2mm takes 46 complete rotations (3312 full turns of the rotary table handwheel). This would be multiple hours to cut a 2" disk.
If the disk is thin, then these procedures would be very easy, except then I'd have no thickness to make the 3 jaw-holding recesses on the back. I guess I'd have to superglue it to a glue chuck.
Please explain to a complete noob how to make a circle out of (relatively) thick stock. Thanks.
