- Dec 22, 2015
- 561
I live in the country and sometimes I need a bolt that is not in my small supply. It's a 30 minute drive to the only hardware store in the little town near me and they often don't have what I need. The next option is to drive an hour each way to the City and get it, or MAKE it. So far I have tried a few methods and I'm still looking for the easiest / fastest way to do this. I usually have the tap and dies I need to cut the threads but making the head is the issue. I have tried using a large diameter rod and cutting it down to size, then using the RT in the mill to cut the head but that is very time consuming. The one I find the easiest so far is to cut the threads I want on a piece of round stock then, if I have the right size and pitch nut, to thread it onto one end then weld in on and finish the surface in the mill or lathe. If I don't have the right size nut I will either drill out the threads on the nut or turn the one end of the rod down enough to accept the nut then weld it on.
I've thought about using hex stock but can't find any near me. However if that is the best way then I can order some from somewhere in the web.
I'm sure there are better ways than the way I've been doing it and I'd love to hear (read) them.
