- Sep 23, 2010
- 619
Lots of guys have these benders and some don't really know what they can do easily. Heres how i do the big hoops from flatbar for industrial ladders with the safety cages. I lay out the metal with centerlines and where the radius starts and stops. Then draw lines 1 1/4" apart for the segments where it will be bent or tweeked prob is a better word. Then i make a pattern for the radius i want. Then i start tweeking 3 or 4 places at the first line and check it with the pattern. If its bent too much just spring it back a little and if it needs more just hit it again. After a few minutes you will get the hang of how hard to pull the handle because it doesn't take much...Bob
