Good evening, all.
I'm spiffing up the little Benchmaster horizontal I recently picked up, and I'm at the point where I could use some advice regarding the spindle and bearings. The rear bearing is off, but the front is not.
I tapped the spindle out which obviously removed the rear bearing, and as there seemed no other way to do it, I hope I didn't cause myself any problems. So the excess grease has been removed, but here it sits. Do I do the solvent cleaning thing to remove all of the old grease? Do I bother to remove the front bearing? I'd like to dunk the spindle in Evapo-rust to make the front look spiffy, but I sorta worry about having the bearing in place.
What about the seals? I imagine I can simply put it back together, but if something is available and it's a good idea, I might as well put in new ones while I'm in there and it's apart. The bearings seem to be fine. What is a suitable grease to use for reassembly? Anything I'm missing?
Thanks for any input.
-Ryan
-Ryan
