I had a few points on my credit card and they made me an offer I couldn't refuse. So a few tools followed me home, including a 6" bench vise. It's exactly the same model Home Depot sells for about $70 (https://www.homedepot.com/p/OLYMPIA-6-in-Bench-Vise-38-606/205149972), just from a local brand.
Thing is, I noticed something was off right away, but at first I couldn't tell what. So I decided to take it apart.
Can you see what the issue is?
Well, let me help you: this is a budget tool and it really shows.
First, there are no machined surfaces on the swivel mechanism, so not positive engagement between the mating parts. Second, it was designed to use the bolt retaining the nut as a (very loose) pivot for the base, and just one clamp to keep it locked.
In itself, I think this is a pretty decent tool for the price. The castings are good and beefy. I'm just thinking: could it be improved with some machining? It seems like there is enough material to make the mating surfaces flat and put a small step / recess, so the head swivels on the periphery instead of the central bolt. But I'm not sure it's worth the trouble.
What do you think?
What do you think?
