- Oct 15, 2013
- 314
Hi, new to the forums here.. I'm looking for any suggestions regarding the bench I will be using to mount my TH54 lathe. Here's my situation:
My garage shop is "space challenged" so every inch counts. I have two possible benches to pick from & modify if needed. Bench 'A' stands 36" tall with a depth of ~26", while 'B' stands 33" tall with a 30" depth.
-What bench height would most prefer? (I'm tall at 6'1", is the 36" bench better?)
-How tall are the Atlas factory leg units?
Atlas' installation bulletin states the bench top should be only 14" wide. I guess this leaves open space around/behind the machine. I would think that space is good for storage of "stuff", even though access is kinda limited back there.
-I'm leaning toward the full bench surface, clear back to the wall. Do others prefer having the full bench top? Or is it wise to limit the surface to the suggested 14"?
Thanks for any suggestions! and also thanks for the forums!
Wes
Wes
