Just bought a Dayton 1725 RPM motor to make a bench motor. Did all the research and located all the parts except one. The JT3 arbor that sticks out from the shaft. You have the motor with a large diameter handwheel/flywheel. Out of the front of this is a small stub shaft with a JT3 taper to hold a real precision Jacobs 1/2" key chuck. The chuck is $277. You use the handwheel to slow the spinning or hold the shaft while tightening.
Here is the question. The shaft appears to be 1/2". The handwheel looks to be about 2-1/2" diameter and about 1-1/2" thick. Is there any reason that I can't make the stub shaft and handwheel all one piece out of 6061? The other option is to make the adapter shaft out of 1018 or 1144 as a separate arbor. Then make a press fit aluminum handwheel and slide over the arbor.
Any other options?
Any other options?
