- Apr 29, 2011
- 4
I'm building a stand for my 10" Baldor bench grinder. Since I have limited space in my garage I need to make it compact and movable. I looked at the HTC HGP-10 stand but it's a bit expensive and I don't need or want adjustable height. Has anyone tried one of these or built anything similar? I'm planning on 32" fixed height and 4 leg base with a couple Mason leveling pads in the back corners and 3" locking swivel casters in front. I'm planning to use some 2x1 rect tube I have for the legs. The post is 2" sq tube and the plan is to weld the legs on at 45 deg angles to the bottom of the post. The scrap pieces of rect tube I have are 10" long. That works out to about an 18" square base when you lay it out (see pdf). Does that seem too small? I need it as compact as possible to fit somewhere between stuff when I have a vehicle in to work on it. But I definitely don't want it to tip over in use as the grinder weighs about 135lbs. If anyone has built something similar I would appreciate hearing how big your base is and how well it works. Thanks, Steve
