Guys I'm putting the finishing touches(ex electrical) on my Sears 101.28940 having problems with the belt hitting the Cover Guard when tension.Like the belt is to long which is 37" long and its what the manual calls for.
I have tried to adjust the arm sq head bolt so that when tension it clears the cover guard but then its to loose.
I do have a 36" belt handy if that would work,but I don't know if it is long enought for me to be able to adjust the sq head bolt then put tension on it to where that pin that rides on the rocker shaft.I have done took the spindle apart twice already so can I drop down to a 36" belt and still have room for adjustments?
Next question:These covers are not original to this lathe,and I have them all put togeather and they fit,but there is a bracket arm that I just can't figure out where it goes.I look at the manual which is for 101.28900 but it just does not show how/where it goes on,any ideals on this?
