- Dec 3, 2017
- 2,247
I'm looking for a smart guy to copy . I've got a Grizzly G0705, which is a round column mill/drilling machine. I'm hoping to see an example of a clever contraption to hold the belt cover up out of my way when I need access. I imagined an automobile trunk lift cylinder, but I know I'm not the kind of guy to think that through well enough to make it work. So my best alternative would be to hang an eye bolt in the ceiling above the machine and then run some parachord through it, attached to the lid on one end, and a counter weight on the other. But...I don't like my idea. Since the head goes up and down, the rope would work sometimes and other times the weight would be laying on top of the belt cover. Anybody ever come up with a nice way to retain the belt cover, and have some sort of mechanism to hold it open when you want to?
For clarity, I've got a shelf on the wall behind my machine. The shelf disallows opening the cover fully. I also think letting the belt cover rest on its own metal hinges screwed to plastic is asking for broken plastic. I can cut the shelf, and the problem is solved. I don't want to cut the shelf. And I don't want to remove the belt cover. Any ideas?
