So I have made a hole plate for my rotary table and I want to remove the machining marks on the surface. This will serve no functional purposes but I just want to make it look pretty and get some experience on hand lapping in the process.
The plate is 150 mm in diameter , 10 mm thick. material is hot rolled steel. I have watched a couple of videos on youtube so I have some basic ideas on how it is supposed to be done but I still have some questions :
1) Instead of rubbing the plate on a bigger flat surface which I don't have, is it possible to rub a smaller surface on the plate ? I am thinking of using a 6061 aluminum block with grooves cut on the surface.
2) What's the difference between lapping paste and liquid ? Is one better than the other ? It seems that paste is graded in grit ( 1000, 1200..... etc ) and liquid in microns. How are the two units interconverted ?
3) Paste or liquid, I will likely end up in having some residual left in the screw holes on the plate. Will any harm be done in future use of the plate other than getting polished screws ?
Thanks in advace.
Thanks in advace.
