Beginners question on drilling
mac1911
Sep 29, 2022
743
So as I started a small project
A Chicago Screw to addapt my current Tool Post Stud to be used with the new QCTP
So I have a 1/2” bolt grade 8 which I annealed.
I started with a basic set of drill bits Bosch started with 3/16, 1/4, 5/16 and finally 11/32
Everything went fine until I got to the 11/32 bit , screamed like a banshee , so I figure old bit I will run and buy a new one. I come back and the new bit cuts worse?
Im a bit stumped I have my spindle speed right at 1000 rpm
At the moment. All other bits cut fine to a depth of 2-1/2”
Am I missing something ?
My Drill Dr crapped out a while back and only grinder is at work so I did not bother trying to put a new edge on.
Way too fast. Lower the speed but you may have work hardened the material. edit-actually, your speed may be ok.
Annealed grade 8 bolts will work harden if you get it hot.
Ask me how I know.
Too fast an RPM for that size bit. Try 1/3 of that. Like @Janderso said, you may have work hardened it.
The bigger the diameter the bit, the slower you turn it.
I also say too fast, but not by a lot, that would work out to near 100 FPM; My guess is that you had a dull bit and work hardened it another anneal should fix things. Grade 8 bolts should be able to be drilled without annealing with a bit of speed reduction.
I took some inexpensive diamond files and my 20x visor and dressed up the old drill bit.
Was able to get the hole done down to 2-1/2” plenty deep enough.
My current tap is dull and it just will not bite. Hopefully I have a fresh tap at work.
Its not easy when your equipment is spread out to 3 locations. Fun stuff
there is a lesson in all of this
Yes dont compromise when buying your house and make sure you have ar least a 10,000 sqft shop on site to fit all your stuff!
Anyhow got it done and will try tapping tomorrow
Lesson learned, tools need to be sharp and many more
Step drilling from 5/16 to 11/32 is challenging. There is a lot of stress on the end of the drill bit lips. Anneal again to full critical, and next time take it to full depth with a carbide boring bar. Xynudu style is OK.
Cool project... Anything named after Chicago just sounds better....
It doesn't really matter here, but you shouldn't need to (and probably don't want to) do that. Plain old cheeze grade drill bits will cut that bolt in it's as delivered condition just fine.
There's the first problem I see. Step drilling has a place, but for basic drilling, stepping up a sixteenth at a time, that's one thirty second per cutting lip on the drill... There's not enough engagement to keep it centered up and working as it should. The last step, one thirty second on the diameter, one sixty fourth on the cutting lips, it's gonna act up if the slightest breeze picks up two towns away from you.
I've never heard a banshee scream, but I'd bet the drill bit was moving, the fluts digging in and popping out unevenly... Basically chatter.
Even the slightest (absolute slightest) difference in a drill bit in a bad situation will act very differently. That sounds about right. You can actually use that to your advantage sometimes in a pinch.
I'd probably back that speed off a little, but at 11/32, it should be very doable at that speed. It'll want a fairly quick feed rate though. And some meat to cut. For a one time setup, no production line pieces, I'd probably pick a speed at five or six hundred for the whole thing and never look back. If I was making a dozens I might worry more about finding the most productive speed with each drill size.
Well yeah.... Same thing I'm missing every time things don't go my way.... And if you ever figure out what it is, I want to know....
This is one off those things where there is a lot of ways to skin a cat. And they're not all wrong. My way, were it me, and were I taking this project on from scratch, I'd "dimple" a center with whatever center drill was handy. (The drill point, NOT the actual center profile). Just enough to cradle the web/split point of the drill I was going to use. I'd be inclined to grab a 5/32 pilot drill, because that's what I keep for that use, and plow that in as far as it comfortably goes. Or maybe 3/16 if I had to pick one out of the index, as I think that's the first one that'll hit your two and a half inches. Then I'd go right to the 11/32 drill bit (which probably won't be deep enough to have a pilot all the way, and it won't matter at that size). And just feed it steady, stopping to clear the chips as needed. That 11/32 drill bit should be plenty able to plow it's own hole from scratch, it'll easily follow a pilot in that range, and by the time it "bottoms" if the pilot is short, it'll be well supported and guided by the time it gets to the bottom of the pilot and starts to clear it's own center. Getting the majority of the cutting lip engaged makes the whole thing go a lot smoother. And your drills last longer.
You can indeed work harden grade 8 bolts if you try to "careful" with them too much, but they're usually not bad. Keep chips coming out (not dust from a one sixty fourth depth of cut/one thirty second on diameter), and they're usually pretty decent to work with. I doubt you actually did that here, as with that small of an engagement, I honestly think you'd have wrecked your drill if the metal turned hard on you.
Yeah Im sure I have been to completion on projects that where “wrong” but got there anyway.
Im not a machinist and grew up around “you need to step drill or pilot hole” . After looking at the bits through a 20x visor I could see the “wrong” right on the bits cutting edge. I managed to get it done by dressing the bit up with diamond sticks. Learning as I go.
I know grade 8 are strong but I was not sure how hard. So while at work I annealed it. Later learned grade 8 is strong but not really “hard”
Quick google search seems to show a 35 - 45 hardness depending on the. Many alloys?
Also of course doing a learn while you turn method I started thinking about feeds speeds and chip load and cutting surfaces and many other things and it dawned on my that the feed/speed/load and everything else gets fubar if you only contacting a small percentage of material or cutting surface.
Fun stuff.
Just need the time to finish up the Chicago or sex bolt. I have plenty of other grade 8 bolts if this fails.
I will attempt to harden andcthen temper it. Used to do it with home made knives years ago so I will give it a whirl
