I am in the middle of restoring an old Canedy Otto drill press and disassembled the quill/spindle assembly today. The two Federal bearings pressed onto the spindle had small 'shims' installed. The spindle was a bit smaller in dia than the bearing. What are these 'shims' called? In the process of removing the bearings, not knowing these shims were in place, I managed to damage one of them and need to replace it. Thus the need to know what they are called. I don't understand why they were used in my case as the spindle dia was about 0.100" smaller than the bearing ID. I don't understand why they simply didn't make the spindle the correct size.
If someone has a good suggestion as to a good source of these shims, it would be appreciated.
Thanks
Jim
Largo, Fl.
Thanks
Jim
Largo, Fl.
