Well I try to learn something on this lathe, right or wrong, every time I use it. I have a friend that rebuilds test equipment, dial indcators, hight stands ect. He has been teaching me how to read the guages and do some set up work.
Ive been having some problems with my feed towards the head stock getting to a certian point and stopping. He told me to pull everything apart and clean it. So I did, wasnt sure what I was in for. He also looked at my bed ways and found that in a bout a 3 inch long area theres so wear. Hes going to bring some equipment over and measure the differasnce for me. He also agreed that I need to go to the class in Ga to learn how to scrape them. But first he gave me a name of a guy that rebuilds machines right here in my back yard! So I took off to his shop and talked with him a bit. Hes an old guy that used to rebuild machines for all the textile mills in the area. Then he turned me on to a small shop in town, NEVER knew it was there and Ive lived here 14 yrs, and he gave me some pointers on what to do about the feed, clean it mostly first.
In the first pic, where the screw driver is pointing, are these whats called the jibbs?
2nd pic, I didnt know there was something to adjust the lever for the half nut. I turned it about 1/2 turn, much nicer now.
In the third, how would I tell if the nut is worn?
