- Dec 11, 2013
- 302
I got this lathe an Atlas TV36 for $50.00 and have spent some time cleaning it up. and collected a few things accessories and the like.
I've learned a lot about some things but still I'm a rank amateur at this stuff.
Here are a few picks of the lathe and the bed. it has wear on the surfaces where both the carriage and tailstock ride. I did a map of sorts on the bed and the wear. I measured the thickness of the Inner & Outer edges of the bed where the moving parts ride and the width where the carriage would wear the front and rear edges.
(See attached PDF of a spreadsheet). I need to understand how bad it really is.
The Bed Width doesn't look like much of an issues so much as the bed thickness.
I've tied to turn a 5/8' x 12" Rod down to 1/2" and there are variances in the diameter all long the rod.
I like old machines as compared to new. This lathe has a 99. % complete set of change gears (missing 1 - a 48 tooth gear). The accessories make it a pretty complete machine as well.
So I'm trying to decide:
A - Is it worth it to re-surface the bed. I have a blind sight unseen quote of $800.00.
B- I understand there is additional work involved IE: on the Carriage Saddle and such but don't understand why or exactly what/where.
If it's worth the money to resurface and it can be made nearly new (or better) I'd probably go for it and in the process strip it down clean and paint.
