Those are good bearing numbers, just not necessarily complete. They are missing additional characters which show the variations, and manufacturers change the numbers, the prefixes, and the suffixes to try to keep you a customer. The Chinese just put the base numbers on them, so that number does not tell the whole story.
You will find stuff like:
205 typically an open ball bearing, no shields or seals
205ZZ double shielded Z would be single side shielded, though not dirt proof
205SS double sealed with rubber seals, keeps grit out
6205 variations (and thousands more)
bottom line, it is likely a 200 series bearing, 25mm bore, 52mm OD, 15mm thick. Confirm that...
A local bearing house will be able to help if you bring in a sample and tell them it is for a metal working machine. I recommend you do NOT buy the really cheap bearings from China (regardless of cost.) Get good American or European bearings, and watch out for counterfeits, which are everywhere. Use a provider who can be trusted. Unless there is a specific good reason not to, I would use double sealed bearings every time unless there is a specific reason for doing otherwise. HF only wants it to run during the short warranty period, you want it to live forever so you don't have to tear it down again, and run smoothly and quietly. Saving a couple dollars and having further problems, even damaging machine components, is not a smart repair.
Bottom line, those bearings are common and cheap, and easy to find. Get some decent ones. Sources like Fastenal, Grainger, and others usually have decent quality stuff. The best bet is to take a sample with you, and explain the application. Hope that helps.
