- May 5, 2013
- 310
Hello All, have been away from machining for a while but looking to get back. Cabinetmaking pays the bills.
I am planning to build a 2" x 72" belt grinder for knife making (as well as general grinding). My plan is to use 1.375" OD x .625" ID bearings.
On the idler wheel (Aluminum) my press fit will be .0002 - .0004" (bearing into wheel). This wheel will slip fit onto the shaft and be held in place with a flange and machine screw into the end of the shaft.
On the 10" contact wheel, I am making a housing to hold the 2 bearings. I will press the same bearings into each side of the housing, with the same tolerances. My instinct is that this shaft should have an interference press fit into the bearings as well. Then the contact wheel (slip fit) will be held on with the same arrangement as above.
My 2 questions:
Are my tolerances correct for press fit bearings?
Should the shaft be pressed into the bearings, that are pressed into the housing? At the same tolerance?
Thanks, Larry
My 2 questions:
Thanks, Larry
